Date/Time: Sat, 01 Feb 2025 12:40:29 +0000
ACISL indicator no longer works.
View Count: 708
[2019-07-15 02:15:19]
TraderTen - Posts: 80
Years ago SC built an indicator to my specs using the ACISL language. In the past year, it started to not work on some of my charts. Now today I can confirm that it works on none of them which it was applied to. There is just a blank studies window.
Has something changed in your platform? I am running the current version.
[2019-07-15 07:31:01]
There certainly are changes over time with ACSIL which may require a recompile of the study. Do you have the source code for the study? If so we can make it work for you.
Date Time Of Last Edit: 2019-07-15 07:31:06
[2019-07-15 17:24:23]
Well, I do not know if I have the code, as I just described to them what I wanted and they built it. However, attached is a copy of a dll file I have in my SC Data folder with the same name as the original, and this goes back to 2013. File type is Application extension.
See if this is what you need. (having trouble uploading the file). If does not work, I will have to try a new message to attach it to.
Private File
