Date/Time: Sat, 01 Feb 2025 12:59:37 +0000
Auto Trading System Start Time End Time
View Count: 2353
[2019-07-14 00:19:00] |
User235492 - Posts: 16 |
Hi Everyone, I use the Trading System Based on Alert which has: Start Time for Allowed Time Range:16:00:00 End Time for Allowed Time Range:15:55:00 It seems like the time I implemented does not work. How is the time supposed to be inputed here? It's not explained in the technical manual. Any videos on it? Thanks, Dennis |
[2019-07-15 07:16:59] |
Currently there is not support for reversed session times for those Inputs with the Trading System Based on Alert Condition study. This will be supported in version 1949. You also need to set this input to Yes: Allow Trading Only During Time Range Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-15 12:15:01] |
Hi SC, Futures trading has a halt at that time or you will be charged margin. So, I need to have my system stop from 15:55:00 to 16:00:00, then start back up again after 16:00:00. Thanks, Dennis |
[2019-07-15 13:27:49] |
ForgivingComputers.com - Posts: 992 |
If you want to avoid overnight margin, then you will probably need a more advanced trading system. I don't think the Trading System Based On Alert Condition Study will flatten any positions when the end time is reached, it will only prevent new positions. I can help you with a trading system that will flatten the trade at the end time. Contact me by direct message or email if interested. brad@forgivingcomputers.com Date Time Of Last Edit: 2019-07-15 13:28:12
[2019-07-15 17:53:08] |
Hi Brad, Yes, I want my system to stop trading at that time. I will use trade management to handle the positions. Global Profit/Loss Management: Flatten Positions at Set Time Thanks, Dennis |
[2019-07-15 18:30:55] |
Sounds good. One workaround to the current study limitation would be to create a duplicate of the study and split up the start and end times where one trades from 16:00:00 to 23:59:59.999 and the other trades from 00:00:00 to 15:55:00.
[2019-07-15 18:47:07] |
User90125 - Posts: 715 |
Curious thing though. Are any of the futures symbols that you trade active during the exchange halt? You might want to restart trading at 17:00 CT instead of 16:00, since the CME Group will shutdown from 16:00 to 17:00 CT anyway. |
[2019-07-15 21:19:40] |
Hi User212764, You only get maintenance margin for the close at 16:55:00 to 17:00:00 CT. Not for the pauses or other halts. Check with your broker. Thanks, Dennis |
[2019-07-17 22:17:31] |
Sorry, the maintenance margin for the close is at 15:55:00 to 16:00:00 CT.
