Date/Time: Sat, 01 Feb 2025 13:03:09 +0000
daily/weekly last bar goes to zero
View Count: 578
[2019-07-13 23:21:04] |
N!co - Posts: 140 |
Hi, many of my weekly / daily chart have there last bar go to zero please advice how to solve this issue thak you |
historical data problem1.png / V - Attached On 2019-07-13 23:20:51 UTC - Size: 42.01 KB - 211 views historical data problem2.png / V - Attached On 2019-07-13 23:20:55 UTC - Size: 41.78 KB - 213 views |
[2019-07-14 08:39:42] |
Uncheck this option for those charts: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#RealTimeUpdatingHistChart We cannot provide further help with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-14 08:39:50
