Date/Time: Sat, 01 Feb 2025 12:52:15 +0000
Bug - Minor
View Count: 689
[2019-07-13 16:54:07] |
User506444 - Posts: 7 |
Studies to Graph>>Settings>>Subgraphs>>Draw Style with down arrow. Click on down arrow slows menu of selections for an second and disappears Doesn't function like other down arrows on the form
[2019-07-13 20:41:57] |
This is going to be a Windows 10 problem. It is not a problem with Sierra Chart and it could not be. Can you believe that Windows 10 cannot even handle something so simple like this? You do not have to believe us if you do not want to. But not all Windows 10 users will have this issue. Only some will. Try doing a Windows update. That functionality is 100% provided by the operating system. Anyway we are going to be working on our own drop-down list functionality and get rid of this Microsoft trash once and for all. And we mean trash. It is nothing but a bunch of trash for the operating system not even to handle something like this properly. Absolute total garbage. Complete garbage. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-13 20:43:29
[2019-07-13 21:28:45] |
This doesn't surprise after the junk that been coming out from Microsoft for 16 months. Current under 1809 Windows 10 home pro that I switch too pro 5 months ago to keep from hanging myself. I set that to maximum year delay for feature update. Other 2 PC are Windows 10 home 1903 that seems to be working good. I set those two to 35 days delay for quality updates. Quality updates cause more problems then they were solving. First time in 18 months I have 3 PC working again. Had an Asus that I couldn't even turn on 3 times in 100 attempts until 1903 was installed. Now it turns on first attempt. Must of done 15 resets in those 16 months that take an week to properly set up again. I no longer feel like organizing an army of 2 million and marching on Redmond campus and impale Lord Voldermort but still believe he the most evil man on earth.
[2019-07-16 19:09:17] |
Anyway it is an active task for us at this present time working to redevelop all of the dialog windows in Sierra Chart to a complete new interface which does not involve any Microsoft components.
