Date/Time: Sat, 01 Feb 2025 12:54:02 +0000
Denali Data feed
View Count: 1012
[2019-07-12 22:46:41] |
TraderTen - Posts: 80 |
I need to renew my Exchange data feed, but it asks if I want Dinali instead. Looks ok to me and at lower price. One question: you have to chose order routing. Currently my orders are routed via Exchange and CQG (AMP). If I change to SC routing for the lower price, will that be a seamless process, without me doing anything else?
[2019-07-15 07:32:53] |
If you are using CQG you just need to choose the $25 Denali Exchange Data Feed service option. You can change to the SC order routing seamlessly. At least somewhat. Fresh data will have to be downloaded for the charts though. This will happen automatically though when the symbols are updated with this command: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-15 07:33:35
