Date/Time: Sat, 01 Feb 2025 13:02:40 +0000
Realtime datafeed question
View Count: 755
[2019-07-13 04:50:46] |
Possibly. What other broker are you referring to?
[2019-07-13 11:56:05] |
FloC - Posts: 23 |
Tradovate (CQG) and InteractiveBrokers My question really is, can I use one datafeed subscription (your SC one or one from a broker like AMP) and use it for historical/realtime data to chart trade all the futures trade services that are available within Sierra Chart ? Date Time Of Last Edit: 2019-07-13 11:57:04
[2019-07-13 20:55:28] |
The best thing to use is one of these data feeds: Sierra Chart Exchange Data Feed Denali Exchange Data Feed And you can use them with CQG or Interactive Brokers and you do not need to involve AMP in this at all. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-13 20:57:03
