Date/Time: Sat, 01 Feb 2025 12:39:16 +0000
How to Run Sierra Chart on MAC
View Count: 11618
[2019-07-12 20:04:31] |
User642945 - Posts: 9 |
Hello, I am new to Sierra Chart and this will be my first time using it....but I have a MAC and I know Sierra is for windows but I have seen some ways to run Sierra on MAC...what do you guys recommend as my best option Thank You! |
[2019-07-13 06:11:41] |
Refer to: https://www.sierrachart.com/index.php?page=doc/SoftwareDownload.php#UsingSierraChartOnMacOS Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
