Date/Time: Sat, 01 Feb 2025 12:43:10 +0000
s_SCTradeOrder - LastFillPrice
View Count: 625
[2019-07-12 19:36:07] |
User796776 - Posts: 95 |
When accessing LastFillPrice in s_SCTradeOrder, it does not contain a decimalized value. Is there a reason for this? In my test case, the fill price was 2979, but the LastFillPrice=297900. |
Screen Shot 2019-07-12 at 3.23.43 PM.png / V - Attached On 2019-07-12 19:33:21 UTC - Size: 97.79 KB - 273 views |
[2019-07-13 00:04:40] |
We have to adjust it by the real-time multiplier. That is the unadjusted value as the TT trading system uses.
