Date/Time: Sat, 01 Feb 2025 12:53:59 +0000
Assign a keyboard shortcut to hide/show a custom study??
View Count: 801
[2019-07-12 18:26:53] |
User600284 - Posts: 9 |
Hi as the subject line says is it possible to accomplish that? I looked into custom study button but I couldn't assign the study to a button. I want this function globally,,,not chart specific. Can you help? Date Time Of Last Edit: 2019-07-12 18:28:32
[2019-07-12 19:02:33] |
No, this is not supported. Unless you create a custom study to accomplish this. How to do that is not within the scope of our support.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-12 19:02:51
