Date/Time: Sun, 24 Nov 2024 19:07:11 +0000
Spreadsheet Buy Entry Values are cleared out when I run Trade > 'AutoTrade System Bar Based Back
View Count: 1445
[2013-12-03 06:58:01] |
rickdane - Posts: 1 |
I'm new to Sierra Chart and very confused at this point. It seems that now whenever I run: Trade > 'AutoTrade System Bar Based BackTest' On my spreadsheet sheet that is associated with my chart, the column 'Buy Entry Values' is cleared out, despite the fact that I have valid functions in there that evaluate to TRUE or FALSE. I can't figure out how to get it to actually run against the functions that I use in there. An example function would be: =AND(e4<e3,e5<e4) Any help on what setting I am missing, etc would be much appreciated. Thanks |
[2013-12-03 21:50:10] |
So the formulas you have in cells K3-N3 are getting cleared when you start the back test? This would have to do with the Formula Source Sheet Number input not being set correctly for the Spreadsheet study: http://www.sierrachart.com/index.php?l=doc/doc_WorksheetStudyInputs.html#FormulaSourceSheetNumber Set it to 0. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-03 21:50:42
