Date/Time: Sat, 01 Feb 2025 12:40:37 +0000
bracket order - local or server side?
View Count: 791
[2019-07-12 12:10:42] |
User710679 - Posts: 43 |
Hi, i have a question in regards to the way a bracket order works with Gain & SC. Stage5 bracket orders, when executed, are automatically send and stored on the server side. So, when using SC to trade, are they stored the same way or are they stored locally? thanks! David |
[2019-07-12 16:18:29] |
Gain capital supports Server Side Bracket Orders, therefore refer to the following documentation for how Sierra Chart handles these orders: Attached Orders: Management of Attached Orders when Trading Service Supports Server Side Bracket Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-12 19:14:45] |
thanks for the info! very useful!
