Date/Time: Sat, 01 Feb 2025 09:46:51 +0000
Free trial did not work, couldn't learn Sierra Chart.
View Count: 616
[2019-07-12 01:25:09] |
User170821 - Posts: 5 |
During the free trial period, I had problem connecting to data. I didn't get to learn the Sierra Chart. If possible, please extend my free trial. Thank you.
[2019-07-12 14:54:50] |
John - SC Support - Posts: 37656 |
Your account has been activated and the usage time extended. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
