Date/Time: Sat, 01 Feb 2025 09:57:59 +0000
10 minute bar charts
View Count: 623
[2019-07-12 01:07:36] |
User117985 - Posts: 4 |
I have sierra charts installed on two computers is there any reason why one computers shows even time stamps the bar charts using 10m time frame, for example on my first PC it will display the times in the following format on the chart, 9:00 then next candle it is showing 9:10 which is how I would like it displayed. However using the same exact chart layout on another computer it will display as the following instead 9:05 then 9:15. How come one chart is showing even time :00 where the other PC is showing :05 increments?
[2019-07-12 01:53:00] |
This is affected by the Session Start Time. This is all explained in detail here: Chart Session Times: Bar Starting Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
