Date/Time: Sat, 01 Feb 2025 12:59:18 +0000
Auto Trading System
View Count: 711
[2019-07-11 19:50:46] |
User235492 - Posts: 16 |
Hi SC, How do I make sure my auto trading system is not taking trades 3:55PM to 4:00PM Central Standard Time? Thanks, Dennis |
[2019-07-12 04:06:25] |
We need to know how the trading system is implemented. For the different methods, refer to: Automated Trading Management Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-13 12:58:07] |
I use the Trading System Based on Alert which has: Start Time for Allowed Time Range:16:00:00 End Time for Allowed Time Range:15:55:00 It seems like the time I implemented does not work. How is the time supposed to be inputed here? It's not explained in the technical manual. Any videos on it? Thanks, Dennis |
