Date/Time: Wed, 24 Apr 2024 06:58:02 +0000
Study Alerts Auto Disable
View Count: 1548
[2019-07-11 12:40:20] |
ILIM KIRGIZ - Posts: 187 |
Dear Support, I preconfigured some study alerts. I make them enabled when I do need them under certain conditions. After that when the alert is triggered once I need it to be disabled automatically. Is there a way to achieve this via GUI or spreadsheet formula? Thanks. |
[2019-07-16 13:51:44] |
I also read the documentation but I could not figure out a solution for that. It would be great if you can guide me. Thanks. |
[2019-07-16 15:38:06] |
John - SC Support - Posts: 31059 |
There is no support to automatically disable an alert once a condition has been met. The only option is to manually go to where the alert has been created and uncheck the option for Enabled. We have been thinking about a way to do what you are requesting, but have not found a reasonable answer yet. If we do get this into a release soon, we will update you through this thread. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-26 10:55:24] |
Thank you. There are lots of situations where traders need an alert to be triggered once and then disabled such as symbol alerts.
[2019-07-28 00:20:44] |
Ok we will look at adding an option to disable a charter study alert after the initial trigger.
[2019-08-01 08:12:46] |
Great, Symbol alert options such as monitoring options (once or continuous) and alert log and/or alert pop up display are great and It would be marvelous to have them in study alerts as well. Thank you. |
[2019-08-15 18:30:53] |
I see that you added option as "disable simple alert after trigger' Thank you very much for adding this feature. You saved a lot of time for me. Is there a way to push study alerts into alert pop as well? Or what is your best practice suggestion to be notified by study alerts? Thanks again. |
[2019-08-15 19:26:16] |
A new pop-up option has also been added for alerts. You can set the pop-up to show or not within the alert number itself. Refer to the following: General Settings Window: Add Alert to Compact Alert Popup Window (Global Settings >> General Settings >> Alerts >> Additional Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-16 12:21:24] |
Great! Thank you. I was looking for wrong place to be able to find it. |
