Date/Time: Thu, 28 Nov 2024 11:54:07 +0000
using autotrade spreadsheet on more than one symbol
View Count: 1320
[2013-12-02 21:46:13] |
User021827 - Posts: 174 |
Can I use a auto system spreadsheet on one symbol while using an auto system spreadsheet on another symbol at the same time ? Or can you only use one spreadsheet for autotrading at a time. thanks |
[2013-12-03 01:34:10] |
Yes. This will work. You can work with auto trading on multiple symbols.
[2013-12-03 01:36:52] |
thanks |
