Date/Time: Sun, 24 Nov 2024 20:39:50 +0000
[User Discussion] - Cannot get spreadsheet to work.
View Count: 1340
[2013-12-02 20:58:17]
jesslinn - Posts: 108
This is my first try at bringing up a spreadsheet and I cannot get it to display any data. Any ideas?
Version: 1056 non-clr
[2013-12-03 02:11:08]
There really should be no problem with this at all. Make sure you have the correct Sheet# selected.
Date Time Of Last Edit: 2013-12-03 02:11:28
[2013-12-05 16:29:54]
I have no idea what the problem was. I was getting no response at all, no matter what or where I entered values. Now, when I follow what I think are the same steps, cells get populated. I did move to 1058 but I assume that I am doing something different.
A few things do not work as expected but it could just be that the documentation does not quite match the version. In particular:
1) ##HD does not produce headers nor can I find anyway to get the headers.
2) Putting the symbol into column A produces results but whenever I do what the document says and prefix the symbol with a # or a / then I get all zeroes in the populated cells.
3) What do you mean by "Make sure you have the correct Sheet# selected"?
4) I cannot access data from other instances of SC. Like Quote Boards, it does not work for symbols except those in the local datafeed. Does this mean that I cannot use spreadsheets to take data from multiple datafeeds?
[2013-12-05 19:09:18]
1, 2. This is still under development with the new Spreadsheets.
3. We thought you are using the Spreadsheet study.
4. No unless you use the Spreadsheet study on a chart opened from a remote instance.
