Date/Time: Sat, 01 Feb 2025 10:00:58 +0000
EPIQ
View Count: 831
[2019-07-10 19:58:04] |
User117754 - Posts: 3 |
Hello, I have enable the EPIQ in Sierra Charts (1928) but i doesn't works... So i ask me if this option work for all datafeed provider (future Contract) ? Thx for your feedback. Regards Ludo. |
[2019-07-11 01:42:21] |
The Estimated Position in Queue will work with any provider, as long as there is Market Depth information at the level of your limit order. There are three options which have to be enabled to actually see this. This is all documented here: Global Trade Settings Windows: Enable Estimated Position in Queue Tracking (Global Settings >> Chart Trade Settings >> General >> Position in Queue) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-11 06:22:13] |
So i have a problem :( I use CQG WebAPI and AMP Clearing broker. I have setup and enable the EPIQ correctly but i haven't the EPIQ value. Have a idea where is the problem ? |
[2019-07-11 06:27:13] |
At the top left of the Global Settings >> Chart Trade Settings window there is an option named "Display Estimated Position". Enable that.
[2019-07-11 07:03:02] |
AHhh yes effectively :) Thanks you ! Regards Ludo. |
