Date/Time: Sat, 01 Feb 2025 12:50:18 +0000
How to measure with Chart Calculator in a study?
View Count: 1288
[2019-07-10 19:09:03]
TedMar - Posts: 190
Hi, i added Diffrence Study,use them as Main Grapgh, but if i measure , i get symbol data/value only. How i can messure scale of Study?
image2019-07-10 21_05_58-Window.png / V - Attached On 2019-07-10 19:08:07 UTC - Size: 25.84 KB - 296 views
[2019-07-10 19:34:06]
You need to look at the Price Difference with the Chart Calculator line. Be sure to enable that option in the Properties for that tool.
[2019-07-10 19:49:40]
TedMar - Posts: 190
U not understand me , in example i use "Dfference(Bar) study". maybe is better new easy example with MACD. check them
image2019-07-10 21_48_20-Window.png / V - Attached On 2019-07-10 19:49:03 UTC - Size: 16.59 KB - 297 views
[2019-07-14 10:21:41]
Ackin - Posts: 1865
I tested it and have too, I don't think that it's right. Maybe ... there is a new "default settings" .
