Date/Time: Tue, 04 Mar 2025 12:26:47 +0000
Delta as bars
View Count: 4866
[2019-07-10 14:52:55] |
User33743 - Posts: 83 |
Hello, I was trying to get Delta Value as bar so it would be presented like Volume. I use study "Number bar calculated" to get ASK-BID Value but cannot find study which would draw the bars. Could you help me? Date Time Of Last Edit: 2019-07-12 01:33:40
[2019-07-15 07:35:32] |
There are a number of ways to do this, but since you are already using the Numbers Bars Calculated Values, just add the Study Subgraph Reference study and set it to reference the subgraph of the Numbers Bars Calculated Values for the Ask Bid Difference Volume. Then set the Subgraph of the Subgraph Reference study as you desire to see it displayed. Refer to the following for the Study Subgraph Reference: Study Subgraph Reference And refer to the following for changing the Draw Style of the subgraph: Chart Studies: Subgraphs Tab >> Draw Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-10 17:20:47] |
user2837 - Posts: 76 |
I was able to obtain this feature as you indicated, which is by combining the Numbers Bar Calculated Values study with the Study Subgraph Reference study. But all the bars are the same color. Is there a way to color the positive values green and the negative values red?
Date Time Of Last Edit: 2021-02-10 17:21:07
[2021-02-10 17:34:26] |
Ackin - Posts: 1865 |
Auto Coloring Based on +/- Chart Studies: Subgraphs Tab >> Auto Coloring |
[2021-10-27 07:09:52] |
vddfollow - Posts: 18 |
Dear all, I have the same demand but bars with tails. Anyone have an idea ? Thanks |
[2021-10-27 13:54:29] |
John - SC Support - Posts: 38341 |
Anyone have an idea ? We are not sure exactly what you are looking for, but take a look at the Ask Bid Volume Difference Bars study and see if it does what you are wanting. Refer to the information here: Ask/Bid Volume Difference Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-27 14:26:00] |
Perfect John !
[2021-12-12 12:32:18] |
User509345 - Posts: 44 |
Hi, John Can Sierrachart add swing delta bar with zigzag? thanks. |
[2021-12-13 16:34:56] |
Take a look at the Zig Zag Cumulative Volume study. This can be set to accumulate Ask Bid Volume Difference volumes. Refer to the following: Zig Zag Cumulative Volume For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
