Date/Time: Sat, 01 Feb 2025 09:52:49 +0000
[Programming Help] - Erase Last Drawing and Erase All Drawn Volume Profiles commands do not work
View Count: 783
[2019-07-10 10:18:43] |
tesseract353 - Posts: 66 |
1. For some reason Erase Last Drawing command is not working on drawn Volume Profiles. 2. The Erase All Drawn Volume Profiles command does not work after Erase Last Drawing command is used. |
[2019-07-11 03:56:20] |
We do see why this condition happens and that is because the associated Chart Drawing for the Volume Profile is being deleted but not the actual Volume by Price study. We will resolve this. This has been resolved in prerelease 1947. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-11 16:13:44
