Date/Time: Sat, 01 Feb 2025 10:00:26 +0000
Ver. 1939 /Cant Roll Back
View Count: 665
[2019-07-09 14:22:05]
User371906 - Posts: 141
I am trying to change version as I always do by using Help / Download Current Version, the program gives the usual “The Software update has been downloaded” by pressing either Yes/No it doesn't return the usual box that allows change of version.
Tried the other options Help / Download Prerelease and also Help / Install Previous Version to no avail.
Current version is 1939.
Trying to change to pass version, what else can I try to be able to roll back.
Thank you
Date Time Of Last Edit: 2019-07-09 14:23:05
Private File
[2019-07-09 16:34:36]
Based on the log the installation of version 1939 succeeded.
Use the installer directly with this link:
https://www.sierrachart.com/downloads/SierraChartFileDownloader.exe
Here are the instructions to go to a specific version:
Software Download: Software Rollback Procedure
