Date/Time: Sat, 01 Feb 2025 12:56:37 +0000
Reference one contract to trade another.
View Count: 982
[2019-07-09 14:13:25] |
User235492 - Posts: 16 |
Hi SC, Is there a way to reference one futures contract (Emini) to trade another (Emicro)? Thanks, Dennis |
[2019-07-09 17:58:19] |
Yes. Use this setting: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-09 20:53:44] |
Thanks for the help SC!
[2019-07-13 16:38:29] |
User972768 - Posts: 166 |
Quick question in regards to this ticket, if I may. When we configure chart to show one instrument and trade another one, what ChartDOM market depth is showing? For example, let's say we plot ES chart and want to trade MES. Do we see MES market depth in this configuration? If it is MES market depth, is there a way to see ES market depth? Thanks |
[2019-07-13 18:11:17] |
When I did this I saw the ES data but trades did not execute correctly. I switch to just the micro and did backtesting (30 days) with just the micro. Hope this helps. |
