Date/Time: Sat, 01 Feb 2025 09:53:01 +0000
Trade Activity Displaying wrong currency value per tick
View Count: 1360
[2019-07-09 06:25:18]
enemyspy - Posts: 306
Using Interactive brokers.
Set up is Dtc Server connected to 3 clients (Sub instances).
Symbol MYM.
Global Symbol Settings >> MYM >> currency value per tick 0.5. (Using Defaults)
Reports in trade activity log seem to be using a currency value of 1/tick on MYM instead of 0.5.
Additionally reports are not adding round trip commission to trades (0.94). The custom value is enabled for this setting only.
Is there a setting I am missing somewhere that can cause this behavior?
Date Time Of Last Edit: 2019-07-09 06:26:48
[2019-07-10 05:17:12]
We need more information as to how you come to this conclusion.
Can you provide a screenshot showing a particular part of the Trade Activity Log you are looking at.
[2019-07-10 13:56:15]
Attached is a screen shot of the trades tab. I have highlighted boxed the fields that caused me to arrive at the conclusion.
The commission column is out of view but all those say 0 instead of 0.94 as well.
Hope this helps.
Date Time Of Last Edit: 2019-07-10 20:47:22
Private File
[2019-07-10 22:54:42]
We see what the problem is. The symbol is not correct. You need to change the symbol in the charts and anywhere else it is used to this format:
MYM-######-ECBOT-USD
Refer to:
Changing the Symbol of a Chart
After that reconnect to the data feed:
Also update Sierra Chart to the current version:
Date Time Of Last Edit: 2019-07-10 22:56:14
