Date/Time: Sat, 01 Feb 2025 12:58:15 +0000
[Programming Help] - Alert condition with TICKSIZE
View Count: 1088
[2019-07-09 04:53:46]
User354816 - Posts: 21
I am trying to display a very simple background condition.
The condition is true, when the VPOC is on the second place compared to the high or low.
I used the formula OR(ID2.SG42=H - 1*TICKSIZE, ID2.SG42=L + 1*TICKSIZE)but it doesn´t seem to work ?!
Thank you for your help !
Best regards
Hauke
imageScreenshot_45.png / V - Attached On 2019-07-09 04:51:55 UTC - Size: 50.64 KB - 280 views
[2019-07-15 17:15:36]
second try to get an answer...
Best regards
Hauke
imageScreenshot_45.png / V - Attached On 2019-07-15 17:14:58 UTC - Size: 50.64 KB - 297 views
[2019-07-15 17:50:36]
Sawtooth - Posts: 4164
Try this:
- Set the 'Value Format' of the Numbers Bars Calculated Values study to 0.01
- Use this formula:
OR(
MROUND(ID2.SG42,TICKSIZE)=MROUND(H,TICKSIZE) - 1*TICKSIZE,
MROUND(ID2.SG42,TICKSIZE)=MROUND(L,TICKSIZE) + 1*TICKSIZE)
The Value Format setting allows the formula to see the price to the penny.
The MROUND function rounds prices to the ticksize, removing any floating point errors.
Date Time Of Last Edit: 2019-07-15 19:40:37
