Date/Time: Sat, 01 Feb 2025 09:50:17 +0000
Unable to load chart that includes NBs, NBs calc vals, and mkt dpth hg studies
View Count: 1144
[2019-07-08 23:30:57] |
tych23 - Posts: 3 |
Hi, I am trying to load a chartbook (shared by a peer) with multiple charts, one of which includes numbers bars, numbers bars calculated values and market depth historical graph studies. It loads/displays as a blank page and I am not able to access the chart settings for it. All other charts in the chartbook loads fine after changing to CQG symbol. I am on a trial period through AMP (CQG trial data). I have contacted them both and they both confirmed CQG is sending all the necessary data, even in trial mode, to Sierra Charts. Can someone help with this? Thanks for your time |
[2019-07-09 17:44:31] |
So there is a problem just with one of the charts in the Chartbook? To go to the chart settings for a chart, go to that chart and then select Chart >> Chart Settings . There should not be a problem with this. To convert the symbols to the correct symbols, use this command: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-09 17:45:07
[2019-07-10 02:29:53] |
tych23 - Posts: 3 |
Correct. There are a dozen charts in the chartbook. All of them load and display correctly after symbol translation command you recommended. Only one not loading and displaying is the chart with NBs, NBs calculated values, and market depth historical graph studies. I do not have any troubles accessing chart settings on all other charts. The troublesome chart displays as blank window in Windows taskbar when hovering mouse over Sierra Chart running program. When trying to click/access that chart, it takes me to the initial main chart upon chartbook open. Thanks.
[2019-07-10 03:04:05] |
Enter your name and telephone number here: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo Let us know when that is done and we will call you and look at this with remote assistance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-10 03:04:11
[2019-07-10 05:18:58] |
tych23 - Posts: 3 |
Account Info entered. Thanks.
[2019-07-10 18:53:08] |
We tried calling just now but no answer. We will try again. Or let us know when would be a good time. We will try to call closer to that time.
[2019-07-10 21:15:42] |
For the record the problem was that the chart was simply offscreen and needed to be repositioned within the coordinates of the monitor.
