Date/Time: Sat, 01 Feb 2025 09:59:07 +0000
Data confirmation
View Count: 620
[2019-07-08 17:36:27] |
User837393 - Posts: 132 |
Hello, Is there a way to confirm if the data I receive is from either my broker or SC ? If I choose in the data/trade settings SC (all data), the indicator on the top left corner is green but all values are at 0. If I turn data/trade setting back to my broker feed, I see moving numbers By the way what are the meaning of these numbers ? Thank you for the assistance. Best regards. |
[2019-07-08 18:17:23] |
Yes this is explained here and is indicated by the [M] indicator: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices When you change services you also need to change the symbols. Refer to: https://www.sierrachart.com/index.php?l=doc/helpdetails1.php#Symbols Be sure to use the Edit >> Translate Symbols to Current Service command. Refer to: Status Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
