Date/Time: Sat, 01 Feb 2025 10:04:51 +0000
Bad tick on ES data on sierra charts-CQG
View Count: 586
[2019-07-08 01:08:09] |
User599135 - Posts: 1 |
Hello there seems to be a bad tick on ES charts via CQG see screenshot attached and it is causing improper scale on my charts because of it. I did a reload of the charts and the issue still persist.
bad tick on ES data-CQG.jpg / V - Attached On 2019-07-08 01:07:31 UTC - Size: 278.59 KB - 386 views |
[2019-07-08 01:22:34] |
We do not see this data error ourselves. Follow the instructions here: Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.1.2 Deleting and Re-downloading Data. (Easier and Recommended Method) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
