Date/Time: Sun, 24 Nov 2024 19:01:31 +0000
Forex USDJPY / Yen - not calculating P&L correctly
View Count: 1265
[2013-12-02 16:19:08] |
GaryD - Posts: 61 |
I have messed with the global settings, and can get the "Trading Profit/Loss Text" to display correct when flat, but while the position is open it shows two less digits. The display on the chart trade window will not display correctly, but goes the other direction, for example a $200.00 profits shows as $20,000. All other pairs display correct, I am assuming it has to do with the yen 3 digits? My broker is FXCM. Any thoughts? Thanks. |
[2013-12-03 02:04:17] |
Refer to this help topic: http://www.sierrachart.com/index.php?l=doc/helpdetails77.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
