Date/Time: Sat, 01 Feb 2025 09:51:24 +0000
Sierra Chart date to Mulitchart
View Count: 1138
[2019-07-07 08:24:10]
Terry Ko - Posts: 21
Hi
I had subscript HKFE data from Sierra Chart. Can data export to Mulitchart?
[2019-07-07 08:58:40]
Yes you can. Follow the instructions here:
Exporting and Importing Intraday Data Files
[2019-07-07 09:22:28]
Thanks. However, can do the live data feed to Multichart? I mean both live data can use for Multichart and Sierra Chart?
[2019-07-07 19:55:28]
Live data would only be supported if multicharts supports the DTC protocol:
DTC Protocol
