Date/Time: Wed, 05 Mar 2025 22:46:09 +0000
alarm bell
View Count: 888
[2019-07-06 15:39:22] |
User106601 - Posts: 17 |
TY Downloaded update now when ever I log on an alarm bell dings...how to disable. ty |
[2019-07-08 23:26:55] |
There must be an Alert set somewhere within program that is generating the sound. The update would not have made any difference to the alert. It is best to find the alert and if you do not need it, to remove it. You can open the Alert Log to determine the source of the alert. Refer to the following: Alerts Manager: Disabling Alert Sounds Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
