Date/Time: Sat, 01 Feb 2025 09:59:22 +0000
[User Discussion] - a problem about Volume at price treshold alert V2
View Count: 1343
[2019-07-06 08:08:27] |
dianxin123 - Posts: 3 |
Hi, I use study "Volume at price treshold alert V2" ,and I want to have the extension lines associated with the grouping when using the Highlight Adjacent Alerts Minimum Group Size ,just like this: https://www.simplesystemtrading.com/imbalance/ I use the "Extend Bar Value Until Future Intersection" study to put on the lines. I set the Based On for the study to the Volume At Price Threshold Alert V2 and then in the Input Data from Bar for Extension Lines I selected the Adjacent Alert Highlight Top 1 for the top of the first grouping. But it show only one bar(the top) ,I want to show all bar in the group. Thanks |
Attachment Deleted. 屏幕快照 2019-07-06 下午3.55.23.png / V - Attached On 2019-07-06 07:57:34 UTC - Size: 154.07 KB - 305 views |
[2019-07-08 09:37:31] |
We will have to see if we can modify Volume at Price Threshold Alert V2 study to support this.
