Date/Time: Sat, 01 Feb 2025 09:51:36 +0000
New Customer
View Count: 651
[2019-07-05 22:48:29] |
Theodore Holoway - Posts: 1 |
I had a free trial I did not have time to use it because I spent all my time with the CompassFX class and I am trying to figure out if I still have what I set up. Can I extend the free trial time to see what is set up in my charting tool? Theodore Date Time Of Last Edit: 2019-07-06 01:49:07
[2019-07-06 01:50:08] |
Your Sierra Chart account is currently active. If you need a trial extension when that ends, just let us know. We also see you are using version 1945. There might be a problem with that version. We want you to update again with Help >> Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
