Date/Time: Sat, 01 Feb 2025 09:59:19 +0000
Setting up 2 instances of Sierra and 2 different data feeds
View Count: 733
[2019-07-05 15:26:10]
User525965 - Posts: 153
Hi, I'm having an issue setting up 2 instances of Sierra chart and 2 data feeds.
I downloaded Sierra twice and logged in with different data connections on each, but once i log in to a data feed on one, it logs the other instance to that same feed as well. How do i keep them each tied to their own seperate feed?
[2019-07-05 16:16:48]
It sounds like that two instances are being connected to the same Trading service and username with that service. The external service you are using which is Rithmic in this case may not support that.
Date Time Of Last Edit: 2019-07-05 16:17:35
