Date/Time: Sat, 01 Feb 2025 09:55:55 +0000
Question about exporting multiple data symbols mixed together please
View Count: 654
[2019-07-04 17:52:49] |
User625613 - Posts: 6 |
Hello!, Just a quick question before i pay the(very reasonable) fee for the service. If I need to export to a csv file the data(minute and above is fine) for two symbols at the same time, can calculations that are done on both of the symbols be done before exporting, such as correlation. And would the time stamps then be the same? Thank You! Date Time Of Last Edit: 2019-07-26 22:02:01
[2019-07-05 15:42:18] |
There is capability to accomplish what you want. You would need to use this particular study: Add Additional Symbol And then perform whatever calculations you need in that chart using the Difference studies or any of the Arithmetic studies. And then export the data with this command: Edit Menu: Edit >> Export Bar and Study Data to Text File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-05 15:50:56
