Date/Time: Sat, 01 Feb 2025 10:04:44 +0000
Uncertain about how to setup Sierra with AMP + SC order routing
View Count: 985
[2019-07-04 11:10:27] |
tomas262 - Posts: 144 |
Hi, I am setting up my account with AMP and their provided SC platform. Now I would like to have orders routed using SC. You discussed it already but I am still uncertain Questions: 1) what to select with AMP platform setup? see the attached screenshot 2) do I understand correctly that I need SC Real-time data stream since using SC routing? (Cannot use AMP data) 3) If 2) is true what do I setup to receive only CME data (YM, NQ + their micro version)? 4) do I need level 2 (Market Depth) data if I trade using range bar charts or just top of book? 5) so the routing fee will be billed from my SC account and everything else will be on AMP statement? Thank you Date Time Of Last Edit: 2019-07-04 11:15:25
AMP-feed-selection.png / V - Attached On 2019-07-04 11:01:00 UTC - Size: 31.54 KB - 285 views |
[2019-07-05 15:15:08] |
1. We think it would be the one that says "New TT W". 2. Yes and you need to use this new data feed: Denali Exchange Data Feed 3. You just need the $20 real-time data service. And you need to activate this exchange: Full CME Group (CME, CBOT, COMEX, NYMEX) for nonprofessional Trading accounts 4. Just the top of book. 5. 5) so the routing fee will be billed from my SC account and everything else will be on AMP statement? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
