Date/Time: Sat, 01 Feb 2025 09:42:46 +0000
study for average range based on time range
View Count: 1143
[2019-07-04 03:03:19] |
User525733 - Posts: 126 |
Hi, is there a study that calculates the average of the daily range for a user defined time period.....for e.g i wanna find the 10ATR for RTH only? thx |
[2019-07-05 17:25:55] |
There is no single study that will do this. You will need to create a separate chart with the RTH only and then use the Average True Range study on that chart. You can then use the Study/Price Overlay study to display the Average True Range on your main chart. Refer to the following for setting Session Times: Chart Session Times And refer to: Chart Session Times: Day Session Only Daily Chart Bars Refer to the following for the Average True Range Study: Average True Range Refer to the following for the Study/Price Overlay study: Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-05 18:39:14
