Date/Time: Sun, 24 Nov 2024 18:22:47 +0000
IB orders - no position
View Count: 1430
[2013-12-02 15:30:14]
jbetlach - Posts: 30
I have a problem with Interactive Brokers orders. Primary order is filled as are both OCO orders. Immediately after the primary order fill, the position is cancelled in Sierrachart, but both OCO orders are active. Sierra shows no position (flat). TWS correctly shows open position and both OCO orders.
Here is the Trade Service log:
Trading Message from IB: Order Event Warning:Attribute 'Outside Regular Trading Hours' is ignored based on the order type and destination. PlaceOrder is now being processed.. Error Code: 2109. ServiceOrderID: 10460. | 2013-12-02 10:21:37
Trading Message from IB: Order Event Warning:Attribute 'Outside Regular Trading Hours' is ignored based on the order type and destination. PlaceOrder is now being processed.. Error Code: 2109. ServiceOrderID: 10461. | 2013-12-02 10:21:38
What is wrong?
[2013-12-02 19:21:44]
Most likely the problem is because Interactive Brokers TWS is not providing updated position data. Could you let us know whether the username you log into TWS with, has more than one trade account on it.
We will run a test.
For now, use the Order Fill Calculated position:
http://www.sierrachart.com/index.php?l=doc/doc_TradeStatusWindows.html#OrderFillCalculatedPosition
Date Time Of Last Edit: 2013-12-02 19:22:02
[2013-12-02 19:23:27]
Yes, the username is for the Friends & Family account with four trading sub accounts.
One other idea: can this be somehow connected with the fact, that I am using Sierra RT feed, which is feeding data into trading DOM?
Date Time Of Last Edit: 2013-12-02 19:25:18
[2013-12-02 19:42:06]
The issue has nothing to do with the Sierra Chart data feed.
You may very well have to use the Order Fill Calculated position:
We are not able to test a Friends and Family account, but we know with those kinds of accounts this could be a problem.
Date Time Of Last Edit: 2013-12-02 19:42:31
[2013-12-02 19:43:09]
I'll try with the Order Fill Calculated position then.
