Date/Time: Tue, 25 Feb 2025 10:28:58 +0000
FreeDll
View Count: 1537
[2019-07-03 20:42:15]
User30743 - Posts: 365
Since freedll is no longer supported in new versions, how do i make it when i want to develop and not keep closing the siera chart due to "Access to the path 'c:\sierrachart_vs\data\tc wtr.dll' is denied."?
[2019-07-03 21:15:24]
John - SC Support - Posts: 38150
Refer to the following documentation, and especially the link to the UDP Interface Port Commands:
Advanced Custom Study Interface and Language (ACSIL): Modifying Advanced Custom Study Code
Also, take a look at this support board post:
ACSIL: Example build script using udp commands to unload / load dlls
[2019-07-11 19:31:13]
why did you change it this way? what was so bad on free dll? and what is better on this process?
[2019-07-11 21:31:35]
Windows 10 has a severe memory leak issue with releasing and loading DLLs and that is why doing a release and load at every chart update is not good and causes a problem.
The memory leak issue was so severe it would eventually bring down the computer system over time.
And also loading and releasing the DLL at every update is simply slow and inefficient.
FreeDLL was a simplified method of DLL management but it was never the best way to do it as it is managed now.
FreeDLL would not work unless it was consistently used throughout all study functions within the DLL.
Date Time Of Last Edit: 2019-07-11 21:32:23
[2021-04-10 21:17:20]
homestar - Posts: 21
I am not familiar with the Windows 10 memory leak issue. Is it recommended to limit the number of UDP dll reloads that are performed?
[2021-04-11 19:19:51]
We do not know . You just have to do testing and see if this is still an issue.
