Date/Time: Sat, 01 Feb 2025 09:57:20 +0000
FDX part of Full CME group
View Count: 688
[2019-07-03 12:34:21] |
User28317 - Posts: 149 |
I changed over to SC data and paid for Full CME Group, I'm not sure if that includes FDX. Do I need additional data? |
[2019-07-03 15:05:25] |
Can you provide us the link to the specifications for this product on the CME website so we know what it is.
[2019-07-04 01:55:06] |
The Futures chart is labeled FDXMU19_FUT_Eurex on SC data feed |
[2019-07-05 08:55:53] |
This is the EUREX exchange. So you just need to activate the EUREX exchange here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures#Exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
