Date/Time: Tue, 29 Sep 2026 18:37:21 +0000
Study or Program for FUTURES risk management - Multiple Entry, Open Orders, Targets
View Count: 1433
[2019-07-03 06:30:38]
NCooley - Posts: 20
PROBLEM
Intraday Trader here, looking to enter many orders for the one position. It is difficult/near impossible to manually enter 50 x 1 contracts for example and then even more difficult to manually move them (risk/take profit) when I should be focused on orderflow.
Is there a program or study that will ENTER these positions when I ask it to (@ market) with the amount of orders and contracts for each, I desire?
A program that can move ALL open orders at once to a price point without having to move one by one?
Also is there a program that can calculate and FLATTEN 1/2 the open positions?
Basically looking for a BE button but instead of BE it can
- move open orders to certain price point of choice (risk/take profit levels)
- FLATTEN 1/2 or 1/3 of open orders. (multiple targets)
Thank you.
[2019-07-03 16:29:08]
Certainly this can be developed using the ACSIL Trading functionality:
Automated Trading From an Advanced Custom Study
Which is a programmatic interface for trading.
And by looking at the studies in the /ACS_Source/OrderEntryStudies.cpp file you can find many examples of order entry studies and the method by which those are triggered through the user interface like menus.
Date Time Of Last Edit: 2019-07-03 16:30:03
[2019-07-04 02:55:36]
NCooley - Posts: 20
Thank you for response.
I am loving the scale IN/OUT.
My only issue now is, how to have multiple targets using the scale in/out automatically?
Any way without manually changing target and having to add new limit orders?
any ideas?
thanks.
[2019-07-05 17:24:55]
It sounds like you do not want to even be using Scale In, therefore every new order added to the existing position will have its own set of Attached Orders.
