Date/Time: Mon, 14 Sep 2026 16:20:54 +0000
deribit data issues
View Count: 1491
[2019-07-02 13:35:28]
User465507 - Posts: 74
the deribit data feed is no longer working. I'm connected to the SC Data - All Services feed.
[2019-07-02 14:00:17]
There is a problem with the Deribit data server on the Deribit side.
[2019-07-15 06:37:20]
Ok we will when we have a problem. What we notice from time to time is that the connection to the Deribit FIX server disconnects within about two seconds of connecting and then we reconnect and then we get disconnected again and this keeps going on and on but after a while the connection succeeds and gets maintained.
[2019-07-18 03:30:41]
Regarding post #3 we are now noticing the problem we described previously:
Deribit Data | Connecting. | 2019-07-18 03:26:14.450
Deribit Data | Connecting to: www.deribit.com:9880 | 2019-07-18 03:26:14.450
FIX Data socket (1) | Creating socket. | 2019-07-18 03:26:14.450
FIX Data socket (1) | Connecting to IP: 51.68.118.121. | 2019-07-18 03:26:14.451
FIX Data | Sending the Logon message. LocalCompID=** | 2019-07-18 03:26:14.753
Deribit Data | Connected to data server. | 2019-07-18 03:26:14.850
FIX Data socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-07-18 03:26:15.845
FIX Data socket (1) | Socket gracefully closed by remote side. | 2019-07-18 03:26:15.845
FIX Data socket (1) | Max send buffers used during socket life: 4 | 2019-07-18 03:26:15.845
FIX Data socket (1) | Signaling to core to close socket | 2019-07-18 03:26:15.845
FIX Data: Socket connection was closed without any logout messages sent or received. | 2019-07-18 03:26:15.845
FIX Data socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-07-18 03:26:15.845
Connection to the external service has been lost. | 2019-07-18 03:26:15.845
you can see we connect, and then we get disconnected from your server. This is an endless cycle. Let us know what details you need.
Date Time Of Last Edit: 2019-07-18 03:31:22
[2019-07-20 04:24:05]
abn2609 - Posts: 15
Hi there,
Any updates on this?
I have also been experiencing data issues with deribit recently.
[2019-07-20 05:24:04]
We have now directly contacted Deribit about this.
Date Time Of Last Edit: 2019-07-20 05:24:11
[2020-07-31 01:23:39]
Adrian O. - Posts: 3
Hi SierraChart Support
Are you currently aware of any issues with the connection to Deribit? I have not received any data updates since 8pm GMT time, it keeps connecting and then straight after disconnecting.
Thank you for your kind attention.
Regards,
Adrian
[2020-07-31 06:10:01]
Deribit has changed their rate limiting functionality which is causing a problem. We are implementing a workaround. This should be resolved in about 10 minutes.
What is really dumb about this, is they only induce more of a problem when they do this.
Date Time Of Last Edit: 2020-07-31 06:10:14
