Date/Time: Wed, 27 Nov 2024 00:24:53 +0000
refresh DOM table at the beginning of each session
View Count: 2782
[2019-07-02 06:32:31]
User531463 - Posts: 1
How do I reset the DOM chart at the beginning of each session. Specifically I am looking at BTP and BUND futures and the traded volumes at each price do not reset at zero at the beginning of the session but still carry over the previous days volumes at each price.
Thanks.
[2019-07-02 15:22:04]
John - SC Support - Posts: 36309
You can only reset the Recent Bid Volume, Recent Ask Volume, Current Traded Bid Volume, Current Traded Ask Volume, and Current Traded Total Volume. It is not possible to reset the Bid and Ask Volumes, as these are the real volumes of resting orders waiting to be filled at those levels.
For more information on how to reset these specific DOM columns, refer to the following:
https://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#ColumnDescription_ResettingResettableTradeChartDOMColumns
Also note the section just above the one in the link about how to turn on the other columns, if desired.
[2020-05-23 17:32:56]
j4ytr4der_ - Posts: 938
It look like there is no option to have the current traded volume columns reset automatically at session start. Is this the case? If so, I would very much like to see that feature added, as it sounds like User531463 was also requesting.
[2020-10-23 07:57:42]
ycomp - Posts: 320
+1 reset recent bid/ask volumes too at start of session
Date Time Of Last Edit: 2020-10-23 07:57:57
[2021-01-15 12:29:46]
NotIll - Posts: 118
how about a +1 for a reset of recent bid/ask volume columns at the start of a new candle for a linked chart?
[2021-11-30 23:12:27]
User866150 - Posts: 14
Bumping this feature request... Impossible to reset between ETH/RTH... Don't have time to babysit the reset either...
[2021-11-30 23:52:09]
Although this would be a really lame workaround... you *could* create an AutoHotKey macro that was timed to trigger your reset hotkey(s) at the appropriate moment. Really though this should be a built-in feature for sure.
[2022-08-16 06:39:18]
503 - Posts: 9
Is there any chance for implementation of this feature?
[2022-08-16 11:58:50]
503 - Posts: 9
GC5150: thanks for this, although I am struggling with adding it on, the 'Add' button is greyed out. I am trying to add it to DOM chart
[2023-02-09 18:34:03]
User708541 - Posts: 87
+1
I'm also very interested in having the ability to auto reset Traded Total Volume at certain designated times. This would be great functionality to have.
[2023-03-09 03:47:13]
Any chance this is ever going to be added? Been a few years now and it sure would be useful.
[2023-08-15 20:34:27]
User652903 - Posts: 25
seconded (thirded, whatever). DOM should be programmable to automatically reset, at the very least, at the opening of the evening and daily sessions. Please add this SC team
[2023-09-24 14:39:17]
User968417 - Posts: 1
Yes, Please add dom reset at session start. Not sure if it has been added but can't find any documentation online.
