Date/Time: Sat, 01 Feb 2025 06:47:21 +0000
Problem with $RVX - can't get past 2/22/19
View Count: 603
[2019-07-01 20:03:49] |
4trading - Posts: 20 |
I am subscribed to SC data historical and RT services, as well as as CBOE. $RVX seems stuck on 2/22/2019. The last date is grayed out and the start date does stay changed. I am able to receive $VIX and $OVX from CBOE however. P.S.Oops. I changed the opening to 08:30, but it did not help the date. Date Time Of Last Edit: 2019-07-01 21:46:24
7-1-19 intraday chart shows RVX for 2-22-19(2).PNG / V - Attached On 2019-07-01 19:03:03 UTC - Size: 157.73 KB - 230 views |
[2019-07-02 05:02:59] |
This symbol is no longer available.
