Date/Time: Sun, 24 Nov 2024 18:42:43 +0000
new H / L sound alert
View Count: 1191
[2013-12-02 12:38:48] |
jaban - Posts: 66 |
Since I reinstalled Sierra , I get a sound alert most likely with a new high or low for the day I cannot find how to get rid of this maybe you can help thanks |
[2013-12-02 22:24:30] |
Refer to this help topic: http://www.sierrachart.com/index.php?l=doc/helpdetails68.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
