Date/Time: Sun, 24 Nov 2024 19:20:52 +0000
symbol formatting
View Count: 1719
[2013-12-02 08:26:43]
Bedhog - Posts: 179
The CTS symbol for CL is CL.CME_20140100_CLF4.CME_NY and the price on the charts is represented as 9310
Price Display Format = 1
Tick Size = 1.000000
Volume at Price Multiplier = 1
The Historical symbol has been set as CL# and the price on the charts is represented as 93.10
Price Display Format = .01
Tick Size = 0.010000
I am unable to make the Daily OHLC overlay on the Intraday charts properly.
On this chartbook, the windows are all linked and I would like this to work for ALL symbols typed into the Intraday chart.
1) Is it possible to format the historical and intraday symbols the same?
2) Should I see [M] after enabling the SC rtdf?
Date Time Of Last Edit: 2013-12-02 08:27:02
[2013-12-02 08:36:53]
Bedhog - Posts: 179
#1) The issue has been solved by choosing "Use Primary Service Server" for the Historical Daily Data Source.
#2) I still cannot tell if the SC rtdf is enabled.
[2013-12-02 09:03:13]
1. Yes that is one solution or adjusting the Historical Price Multiplier in Chart >> Chart Settings >> Advanced Settings 2 for the Historical Daily chart.
2. You should see the [M] indicator after symbol. If you do not, restart Sierra Chart and provide a copy of the Message Log, by following these steps:
https://www.sierrachart.com/index.php?l=PostingInformation.php#log
Also make sure the symbol settings are up to date:
https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings
Date Time Of Last Edit: 2013-12-02 09:03:45
[2013-12-02 09:29:59]
Bedhog - Posts: 179
I see [M] when setting up the chart with the Mini Dow & Nasdaq but not with Crude Oil
OKAY
Symbol: YMZ3
Trade and Current Quote Symbol: YM.CME_20131200_YMZ3.CME_E
OKAY
Symbol: NQZ3
Trade and Current Quote Symbol: NQ.CME_20131200_NQZ3.CME_Eq
DOES NOT DISPLAY
Symbol: CLF4
Trade and Current Quote Symbol: CL.CME_20140100_CLF4.CME_NY
[2013-12-02 09:31:50]
The symbol settings do not make sense. The main Symbol should be the standard CTS T4 symbol. For example: CL.CME_20140100_CLF4.CME_NY.
Trade and Current Quote Symbol should be empty. Sierra Chart will automatically handle the necessary mapping to the symbol used by the Sierra Chart real-time server. There is nothing to do on your side.
Date Time Of Last Edit: 2013-12-02 09:32:33
[2013-12-02 09:48:51]
Bedhog - Posts: 179
I performed the Symbol Full Reset and the log was sent via pm.
Displays [M]
Trade and Current Quote Symbol: <blank>
Displays [M]
DOES NOT DISPLAY [M]
No SC real-time data feed mapping found for symbol: CL.CME_20140100_CLF4.CME_NY | 2013-12-02 03:47:24
Date Time Of Last Edit: 2013-12-02 09:50:39
[2013-12-02 10:05:50]
This is not making sense. It works for us:
http://www.sierrachart.com/image.php?l=1385978652965.png
We did have a look at the Message Log. We see where it indicates there is no mapping found, but there clearly should be.
We recommend opening a new chart for that symbol through File >> Find Symbol and reconnecting to the data feed using the commands on the File menu.
[2013-12-02 10:31:45]
Bedhog - Posts: 179
I did one more symbol reset and this time I did not update the time zone or set the round turn commission.
Now the [M] appears for CL.CME_20140100_CLF4.CME_NY
Back to the other question regarding Data Throughput and Buffering.
If I choose Trade Only, it reverts back to Smart Trade after stopping/starting SC and when disconnecting/connecting with F11.
I do not want 2 data streams arriving.
How do we know that SC is only receiving the SC rtdf and not the CTS rtdf?
Date Time Of Last Edit: 2013-12-02 10:34:56
[2013-12-02 10:36:28]
OK, we see what the problem is. This issue will be resolved in the next release.
If you see [M] by the symbol, then you can be assured that there is no data from CTS being used for that symbol.
