Date/Time: Sat, 01 Feb 2025 06:47:18 +0000
Trade and Current Quote Symbol Attached Orders not Attaching
View Count: 592
[2019-07-01 08:08:07] |
User243331 - Posts: 7 |
Greetings, When using Trade and Current Quote Symbol in Chart Settings and when Use as Trade Only Symbol is Checked, the attached orders do not get attached. So I chart via the NQ mini and send trades to the NQ Micros. I see the main order but not the attached orders. I have a set Stop and Profit Target that I want attached to the main order but it is not being attached when using the Trade and Current Quote Symbol feature. I am submitting market orders and not limit orders. Please assist. Thank you. V/R Dom Date Time Of Last Edit: 2019-07-01 08:10:04
[2019-07-01 11:59:59] |
Check the Trade >> Trade Service Log to see if they are getting rejected. Otherwise, the problem must be that you are setting them on the wrong Trade Window. Refer to: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM (Trade Window Settings Not Applying to Chart or Trading DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
