Date/Time: Sat, 01 Feb 2025 07:00:05 +0000
Draw Styles - hollow rectangle or solid with border
View Count: 1515
[2019-07-01 03:00:56] |
ochocinco - Posts: 29 |
Hi, Im seriously considering a move to SC and spending this month to search the docs and forum to learn. Not sure if Im missing how to do this or if the functionality isnt available. Example: 1 period simple moving average, Is there a single subgraph draw style that would appear as: 1) a hollow rectangle drawn in the "at price" space. I find "Circle Hollow" but nothing like a "Rectangle Hollow". 2) a solid rectangle with a border drawn in the "at price" space. I find solid rectangles "Color Background at Price", but cant figure out a border. Im attaching a sample image of both styles from my current charting software. thanks Date Time Of Last Edit: 2019-07-01 03:04:08
solid with border and hollow examples.jpg / V - Attached On 2019-07-01 02:38:51 UTC - Size: 91.91 KB - 377 views |
[2019-07-01 04:06:36] |
The closest that is available is the "Square" Draw Style: Chart Studies: Subgraphs Tab >> Draw Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-01 04:06:41
