Date/Time: Sat, 01 Feb 2025 06:43:32 +0000
cancel / close my account
View Count: 584
[2019-06-30 16:51:40] |
User798620 - Posts: 29 |
i want to make sure everything is canceled and im not being billed anymore for this account, i dont use it anymore, cant seem to find this info on the site, its been a while since i paid for service, but for some reason i can still login and use it just fine. so i want to check that its been done right...
[2019-06-30 17:11:24] |
Your account is associated with Green Chart. You must contact them. We do not have any control over their billing.
