Date/Time: Sat, 01 Feb 2025 06:56:58 +0000
Days to Load
View Count: 842
[2019-06-30 11:45:40]
samual sprat - Posts: 343
I have a chart in one of my chartbooks which I use to view various time-frames from 1 minute to 1 week. Because of this I enable the "Adjust Proportional with Bar Period" option under chart settings so that I get a good amount of bars when moving to higher time-frames. The problem with this setup is that if you use more than 1 day 'Days to load' on 1m chart, then when loading a 4 hour or above chart, the number of days loaded becomes too high takes very long to load and render the chart. If there was an option 'Max Days to Load' to create an upper limit to 365 days of data, then that would solve the problem.
Is something like that possible?
S
